Baldy95307
Jul 30, 2022Aspirant
C7000v2 – Nighthawk AC1900 WiFi --- Upstream LED remains yellow/orange
New modem/router on Spectrum's system which seemed to work fine for the first 2 or 3 weeks but now I'm wondering if there is a problem. The Upstream LED on the front panel of the device is orange/yel...
microchip8
Jul 30, 2022Master
Do you actually have a problem?
Baldy95307
In performance, nothing noted. Up and down work just fine. With Spectrum its generally around 400 Mbps down and 10 Mbps up. But my questions were pertaining to the different color of the upstream LED on the front of the device and if the amount of uncorrectables on the downstream locked channels was normal.
Perhaps you are thinking the same as me....if ain't broke, don't fix it.
- michaelkenwardJul 31, 2022Guru - Experienced User
And if you do want to fix things with the C7000v2 , try the right place.
Cable Modems & Routers
That's where cable modem users and experts hang out.
