tonytampa
Jun 15, 2020Follower
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router MoCA
Hi,
Does anyone know if the C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router is MoCA compatible? I am trying to run Wired connection to 2 different floors in my house using the existing Coax Cable Network. I am not sure if I will need 2 MoCA Adapters, 1 for the Modem/Router and the other for the second room, or if the Nighthawk is already MoCA Complatible where I will just need 1 in the other room to pull through a wired ethernet connection.
If anyone knows of a better way to run a wired connection without having to run ethernet wiring through the whole house please help!
the C7000 doesn't have moca capabilities built into it.
1 Reply
