Firestorm7120's avatar
Mar 27, 2023
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router: WiFi6(802.11ax)
I'm thinking about buying a mini pc. It uses WiFi6(802.11ax). Will it work with my Nighthawk AC1900?   If not, is there a way to adapt the setup to accommodate the connection? i.e. bridge the PC's ...
  • FURRYe38's avatar
    That would be something to confirm with the Mfr of the PC.
    However generally, most if not all wireless adatper are fully backwards compatible with WiFi 5 modes.
    Just know that the C series modem does not have any support for WiFi 6 anything.
    Good Luck.
