LauraStuart
Nov 05, 2020Follower
C7000v2 - Is this modem large enough for 300mb
Xfinity is telling me that this modem can not handle 300MB
I changed back to 200MB - but their system still can tell me if it's going to work.
Spec sheet says so on the wire:
https://www.netgear.com/images/datasheet/networking/CableModems/C7000.pdf
https://www.speedguide.net/routers/netgear-c7000-ac1900-nighthawk-cable-router-3641
900Mpbs is depending upon ISP support which most ISPs required 32 channels and DOCSIS3.1 to get 1Gb ISP service speeds. However for you needs, this mode should work fine at 300Mpbs no problem.
