Fighter31's avatar
Fighter31
C7000v2 - no internet or wifi
Good evening, Last night my C7000v2 started acting up on me. I’ve had absolutely no issues until now. Some background: It started with my TV yesterday (Samsung) losing internet connection and be...
  • plemans's avatar
    May 20, 2022
    Your logs are indicating an issue with the line. And your power is out of spec.
    For downstream, you should be within 3.5dbmv of each channel. You're going from -9 to 1.1. so over a 10dbmv difference.
    You don't have any errors listed but it means something in the line has issues. couple that with the errors in the event logs and you need to check your lines.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line. Replace any that might be suspect.
    Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
