Hi again, I managed to access my router through a different browser, see the information below:
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 627000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 29 | 627000000 Hz | -8.2 dBmV | 39.9 dB | 0 | 0 | | 2 | Locked | QAM256 | 17 | 555000000 Hz | -9.4 dBmV | 39.4 dB | 0 | 0 | | 3 | Locked | QAM256 | 18 | 561000000 Hz | -9.4 dBmV | 39.1 dB | 0 | 0 | | 4 | Locked | QAM256 | 19 | 567000000 Hz | -9.4 dBmV | 39.5 dB | 0 | 0 | | 5 | Locked | QAM256 | 20 | 573000000 Hz | -9.8 dBmV | 39.2 dB | 0 | 0 | | 6 | Locked | QAM256 | 21 | 579000000 Hz | -9.3 dBmV | 39.4 dB | 0 | 0 | | 7 | Locked | QAM256 | 22 | 585000000 Hz | -9.2 dBmV | 39.3 dB | 0 | 0 | | 8 | Locked | QAM256 | 23 | 591000000 Hz | -9.4 dBmV | 39.2 dB | 0 | 0 | | 9 | Locked | QAM256 | 24 | 597000000 Hz | -9 dBmV | 39.3 dB | 0 | 0 | | 10 | Locked | QAM256 | 25 | 603000000 Hz | -8.7 dBmV | 39.5 dB | 0 | 0 | | 11 | Locked | QAM256 | 26 | 609000000 Hz | -8.7 dBmV | 39.6 dB | 0 | 0 | | 12 | Locked | QAM256 | 27 | 615000000 Hz | -8.3 dBmV | 39.6 dB | 0 | 0 | | 13 | Locked | QAM256 | 28 | 621000000 Hz | -8.6 dBmV | 39.8 dB | 0 | 0 | | 14 | Locked | QAM256 | 33 | 651000000 Hz | -9.2 dBmV | 39.5 dB | 0 | 0 | | 15 | Locked | QAM256 | 30 | 633000000 Hz | -8.3 dBmV | 40 dB | 0 | 0 | | 16 | Locked | QAM256 | 31 | 639000000 Hz | -8.8 dBmV | 39.4 dB | 0 | 0 | | 17 | Locked | QAM256 | 32 | 645000000 Hz | -9.3 dBmV | 39.3 dB | 0 | 0 | | 18 | Locked | QAM256 | 34 | 657000000 Hz | -10.1 dBmV | 38.5 dB | 0 | 0 | | 19 | Locked | QAM256 | 35 | 663000000 Hz | -10.2 dBmV | 38.2 dB | 0 | 0 | | 20 | Locked | QAM256 | 36 | 669000000 Hz | -10.1 dBmV | 38.2 dB | 0 | 0 | | 21 | Locked | QAM256 | 37 | 675000000 Hz | -10.1 dBmV | 37.8 dB | 0 | 0 | | 22 | Locked | QAM256 | 38 | 681000000 Hz | -9.7 dBmV | 38.5 dB | 0 | 0 | | 23 | Locked | QAM256 | 39 | 687000000 Hz | -9.6 dBmV | 38.6 dB | 0 | 0 | | 24 | Locked | QAM256 | 40 | 693000000 Hz | -9.2 dBmV | 39 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 3 | 5120 Ksym/sec | 22800000 Hz | 55.5 dBmV | | 2 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 3 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 4 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
