SpookyBooty
Apr 21, 2020Follower
C7000V2 - portforwarding two xbox consoles - HELP
Hello! I just purchased a new cable modem router to get rid of the one we were renting from Spectrum. It's all set up and running great except I'm having trouble portforwarding my two consoles as...
Apr 21, 2020Guru - Experienced User
How are you connecting the xboxes to the modem? Wired is preferred.
Port Fowarding shouldn't be needed. Only enable uPnP is needed.
You can check to see if you have a feature call NAT Filter in the modems UI. Maybe under Advanced Setup/Internet or WAN setup.
