SR_0410
Apr 07, 2021Aspirant
C7000V2 - Spectrum Cable - every night resetting at same time
I have spectrum cable - ARRIS TM602G modem with C7000v2 nighthawk modem/router combo. Every night at 12:15AM my wifi goes off line for couple of minutes. My event Log shows: - Resetting t...
Apr 07, 2021Guru - Experienced User
i guess I'm curious as to why you're using 2 modems.
SR_0410
Either rent spectrums router for ridiculous monthly charge or get my own - which I did with the nighthawk. Worked fine for about 6 months, till recent issue.
- plemansApr 07, 2021Guru - Experienced User
so you're not using the other modem? Just the c7000?
Do you have a screen snip of the cable connections page and the modem event logs?
- SR_0410Apr 08, 2021Aspirant
Thanks,
1) Here is Event Log: Note: I edited to "X" the mac addresses :
2021-4-7, 23:14:59 Critical (3) Resetting the cable modem due to docsDevResetNow 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;
CM-MAC=x:X:x;X;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:42 Notice (6) WiFi Interface [wl0] set to Channel 2 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:42 Notice (6) WiFi Interface [wl1] set to Channel 157 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:45 Critical (3) No Ranging Response received - T3 time-out;
CM-MAC=x:X:x;X;CMTS-MAC=x:X:x;X;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:48 Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 2021-4-7, 23:16:31 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=x:X:x;X;
CMTS-MAC=x:X:x;X;CM-QOS=1.1;CM-VER=3.0;
2021-4-7, 23:16:31 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=x:X:x;X ;
Happens at exact same time every night.
2) On the setup - the spectrum TM602G is used for Telephone service - coax from wall is split (commscope SV-2G splitter) to this modem alogn with power and phone line .
& Netgear nighthawk for internet is connected to coax/power. Then WIFI to laptops, etc.
Previously I had seperate Netgear router and separate netgear modem - in JUne of 2020 - I replaced these 2 with the Netgear Nighthawk C7000V2 combo - no issues for about 8 months , only the last month or so - at exactly 12:15AM - I get this eve
- plemansApr 08, 2021Guru - Experienced User
I've never seen a setup that uses to modems unless one has a seperate line of service
