HDPirate
Jan 17, 2024Initiate
C7000v2 1 bar
The router is 1 inch from pc. All cables are tight. No obstructions. Only 1 bar on iPhone
Jan 17, 2024Guru - Experienced User
Power OFF modem for 1 minute the back ON.
What channels are you using?
Has a factory reset and setup from scratch been performed?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
HDPirate
Jan 26, 2024Initiate
Yes to everything. I was told that the one bar didn't mean anything. I am using Netgear 80 5G. I don't have any problem other than in my house using wifi.
- FURRYe38Jan 27, 2024Guru - Experienced User
Where are you see this 1 bar at?
What channels are you using on the modem?
