HDPirate
Jan 17, 2024Initiate
C7000v2 1 bar
The router is 1 inch from pc. All cables are tight. No obstructions. Only 1 bar on iPhone
HDPirate
Jan 26, 2024Initiate
Yes to everything. I was told that the one bar didn't mean anything. I am using Netgear 80 5G. I don't have any problem other than in my house using wifi.
Jan 27, 2024Guru - Experienced User
Where are you see this 1 bar at?
What channels are you using on the modem?
