Awongweinrieb
Jul 18, 2021Tutor
C7000v2 ac1900 orange upload, no internet
Model c7000v2, ac1900 wifi cable modem router. My upload light is orange, download is green. Internet suddenly stopped working about a week ago - have been using this router for 2 years with no iss...
- Jul 19, 2021
your upstream only has 1 locked channel. and its running high. Meaning its taking almost maximum power to communicate back to the ISP.
Sure there's no signal attenuators in the line?
Or splitters?
Awongweinrieb
Jul 19, 2021Tutor
Sweet, I moved it to another spot and it seems to work but the upload is still orange.
I'm getting 30mb down and 15mg upload on a speed test. This is on wifi.
My ISP is supposed to give 600mb down.
Awongweinrieb
Jul 19, 2021Tutor
Another screenshot
- plemansJul 19, 2021Guru - Experienced User
you got the logs but not the event logs.
And the cable connections page shows upstream/downstrea/snr/errors/etc. not the other page you snipped
- AwongweinriebJul 19, 2021TutorOh shoot my mistake! Attached event logs.
Still don't have the cable connections page but your logs have a bunch of t3/t4 errors. Tends to indicale line/signal issues.
Check the line for kinks, damage, old/bad/cheap/corroded connections. Remove splitters, amplifiers, or signal attenuators from the line.
