pinkstonms
Sep 03, 2023Tutor
C7000v2 adding wired satellite
I currently have the Nighthawk c7000v2 router. I want to add a satellite (mesh?) on back patio that is covered, so we can have Wi-Fi at pool. I have run Cat 6 ethernet cable from the router to th...
pinkstonms
Sep 03, 2023Tutor
I was told If I run ethernet all I need is something like this sorry not Netgear:
I have an extender really doesn't help much never use.
Sep 04, 2023Guru - Experienced User
Something to contact TP_Link about regarding there product.
This is a forum for NG products. Sorry.
Only NG products that can help extend wifi signals from the C series modem are the EX series extenders which the 7700 and 8000 can be used in AP Mode with a ethernet connection to the C series modem.
Good Luck.
