pinkstonms
Sep 03, 2023Tutor
C7000v2 adding wired satellite
I currently have the Nighthawk c7000v2 router. I want to add a satellite (mesh?) on back patio that is covered, so we can have Wi-Fi at pool. I have run Cat 6 ethernet cable from the router to th...
- Oct 12, 2023
Orbi or NH MESH are compatible.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
https://kb.netgear.com/000061710/What-is-an-Ethernet-backhaul-connection-and-how-do-I-set-it-up-on-my-Nighthawk-Mesh-WiFi-6-products
microchip8
Sep 03, 2023Master
Your router is not compatible with Mesh technology. Either get a new Mesh system like Orbi or MK, or get extenders/access points and use them with your existing router.
pinkstonms
Oct 12, 2023Tutor
So I need to replace my Nighthawk router if I want to install a mesh system?
- FURRYe38Oct 12, 2023Guru - Experienced User
You can configured the C series modem for modem only mode, so you can continue to use its modem for internet services, then yes, connect up a MESH router system.
- pinkstonmsOct 12, 2023Tutor
Thanks Furry for the reply. can you recommend a mesh system that is compatible with my C7000v2 router? I have run an ethernet cables to the locations where I want to put the satellites from the C7000v2. Also if you have a link to the setup that would be great. Is the MK62 or 63 the best option for my router? I found this video:
https://www.youtube.com/watch?v=PwIU3-67pzQ
I want to connect satellites with ethernet.
