Arahn
Jan 11, 2022Tutor
C7000v2 Amber Light Issue
Starting a new topic because I can’t find any issue like mine: My modem/router suddenly stopped supplying internet in the middle of the day. I tried multiple factory resets, power-cycling, the works ...
- Jan 11, 2022
sounds like a hardware failure. What I'd try?
Disconnect if from the coax and hold reset for up to 30 seconds while powered on.
See if that resets it.
If it doesn't, it might be toast.
Is it still within warranty?
Jan 11, 2022Guru - Experienced User
are you able to log into the router and get a screen snip of the cable connections page and event logs?
Arahn
Jan 11, 2022Tutor
No, the wifi doesn’t appear and if I try search for the network using the information all my devices say they can’t find it, so I can’t log in. The nighthawk app can’t find or connect to it either.
- plemansJan 11, 2022Guru - Experienced User
If you hardwire a pc/laptop into it, can you access it at 192.168.100.1
- ArahnJan 11, 2022Tutor
No, even hardwired it still doesn't let anything connect, not even to default access.
