Braadford1
Jan 16, 2023Aspirant
C7000v2, Android, wi fi signal stopped
Have had this modem/router for about a year with no problems. Today while watching TV the picture stopped transmitting. Tried to reconnect via Roku and could not find a wi-fi signal. Unplugged and plugged power to the router and all lights come back on, and then 2.4 Ghz, 5.0 Ghz, WPS, and Wi-Fi lights turn off. All other indicators are solid green. Also did a reset, all lights come on, downstream, upstream, internet blink for awhile then go solid, all other indicators except ethernet go dark. Thanks for any help.
Do wired devices work?
Did the wifi on/off button get hit? Push and hold it for 2-3 seconds.
- Braadford1Aspirant
I am not sure if I have any wired devices. The printer is wireless, which is not working at this time, and the internet is working. I pressed the wi-fi button but nothing happened.
You pushed and held it for at least 2 seconds? Not just clicked it?
Try a hardwired device to see if the c7000 is still working and if you can access the gui
