AramFingal's avatar
AramFingal
c7000v2 being gifted to a friend
I disconnected this c7000v2 cable modem at the end of May because I switched ISP, and I just "filed" it away as a spare.  However, now my friend still on that ISP needs a new cable modem.  I defaulte...
  • antinode's avatar
    antinode
    Aug 12, 2020
    > [...] now I don't see the default SSID listed on the side of the
    > device, [...]
       Not a good sign.
    > [...] so I plug in with an ethernet cable (all while modem unplugged
    > from house cable connection) and http://192.168.100.1 does not come
    > up. [...]
       Also not a good sign.
    > [...] then the device power cycles again.
    > [...] I only get the error message "you are not connected to the
    > internet".
       What's the IP address of your (unspecified) computer/device when you
    do this?
       If the C7000v2 is not broadcasting its/any SSIDs, and if it's not
    giving your Ethernet-attached computer a good IP address, then it might
    be in more trouble than you think.
       I'd try assigning static IP[v4] parameters to the computer, like,
    say:
          address: 192.168.0.10
          netmask: 255.255.255.0
    Then, when that doesn't help:
          address: 192.168.100.10
    But I would not expect much.
    > [...] I did read the manual on Install and activation.
       Did you also look for the LED descriptions and "Troubleshoot"?  Even
    without an ISP connection, I'd expect it to settle down and respond as
    documented after a minute or two.  Unless it has a serious problem
    (other then not being connected to an ISP).
