AramFingal
Aug 12, 2020Aspirant
c7000v2 being gifted to a friend
I disconnected this c7000v2 cable modem at the end of May because I switched ISP, and I just "filed" it away as a spare. However, now my friend still on that ISP needs a new cable modem. I defaulte...
- Aug 12, 2020
> [...] now I don't see the default SSID listed on the side of the
> device, [...]Not a good sign.
> [...] so I plug in with an ethernet cable (all while modem unplugged
> from house cable connection) and http://192.168.100.1 does not come
> up. [...]Also not a good sign.
> [...] then the device power cycles again.
> [...] I only get the error message "you are not connected to the
> internet".What's the IP address of your (unspecified) computer/device when you
do this?
If the C7000v2 is not broadcasting its/any SSIDs, and if it's not
giving your Ethernet-attached computer a good IP address, then it might
be in more trouble than you think.I'd try assigning static IP[v4] parameters to the computer, like,
say:address: 192.168.0.10
netmask: 255.255.255.0Then, when that doesn't help:
address: 192.168.100.10
But I would not expect much.> [...] I did read the manual on Install and activation.
Did you also look for the LED descriptions and "Troubleshoot"? Even
without an ISP connection, I'd expect it to settle down and respond as
documented after a minute or two. Unless it has a serious problem
(other then not being connected to an ISP).
AramFingal
And the manual says "connect a coax cable, connect power adapter, plug in device, when startup procedure is complete, power light stays on ( which does happen). It then says "when the modem comes online, the internet light stops blinking and lights solid green" . This never happens, even after 10 minutes like the manual says. I did read the manual on Install and activation.
antinode
Aug 12, 2020Guru
> device, [...]
Not a good sign.
> up. [...]
> internet".
do this?
say:
- AramFingalAug 13, 2020Aspirant
Bummer. Unfortunately, I may have made this device unuasable. I set the IP on my laptop to 192.168.0.3, with subnet 255.255.255.0, and I cannot get to 192.168.0.1. Just for grins, also tried setting the IP to 192.168.100.3, subnet 255.255.255.0 with no luck also. (the manual says default address is 192.168.0.1) I still don't see the NETGEAR79 network show up in my Wifi list when trying to find it after resetting the device. The LEDs blinking do not correspond to any of the 3 LED troubleshooting references in the manual (a rather surprisingly small number according to what i thought i would find).
Alas, poor Yorick is broken a cable modem once exhumed from my electronics closet. Well, his undoing is mine this time. I do not want to take up any more time from anybody in what seems like a hopeless case, so I will leave this thread to be closed and removed (I don't think it provides any use to anybody who may come behind me to this forum). I really appreciate the responses, and wish everybody good luck in their future forum endeavours.
