Skippy414's avatar
Apr 13, 2020
C7000v2 bridge mode and native wifi
Hello. Just got my c7000v2 and have easily connected with Comcast. Piece of cake.
My question is pretty simple, I think. With my last modem (Comcast Arris rental), in bridge mode, I still had wifi through the modem (downstairs) as well as wifi through my D-Link router (upstairs), with 4 different SSIDs - 2 for each device.
If I swich to Bridge Mode on the C7000v2, will I still have wifi networks originating from the C7000v2?
I don't want to try it until this is confiormed. Thanks in advance!
  • Follow this for your DIR-880L router to configure it for AP mode:
    http://forums.dlink.com/index.php?topic=40856.0
    If you want to use the DIR router in router mode with the modem in router mode and avoid a double NAT issue, you can input the IP address the DIR router gets from the modem and put this into the modems DMZ. I use this all the time for having two routers on the same line.
    Skippy414 wrote:
    The Arris modem did still have WiFi in bridge mode. It also still had the universal xfinity public access WiFi channel.
    The upstairs router is a D-Link  DIR-880L and doesn't appear to have an access point mode (router/bridge).
    C7000v2 Modem subnet: 192.168.0.1x
    DIR-880L Router subnet: 168.192.100.1xx
    I have had it set up with both in router mode since Sunday morning and so far, nothing seems to be amiss, though I read there can be conflicts because of NAT being enabled on the C7000v2 Modem.
    The only things recorded in the event log on the C700v2 are 2.4GHz WiFi channel changes.
  • FURRYe38's avatar
    When using bridge mode, wifi and all router functions are disabled.
    • Skippy414's avatar
      Skippy414
      Tutor
      And there's no way to get around this if I don't want to create conflicts, but keep all four wifi networks? Could I assign a static IP to the router and leave the modem in router mode, for instance?
      • antinode's avatar
        antinode
        Guru
        > [...] With my last modem (Comcast Arris rental), in bridge mode, I
        > still had wifi through the modem (downstairs) [...]
           Sounds unlikely.  "Bridge mode" and "WiFi" generally are mutually
        exclusive.
        > And there's no way to get around this [...]?
           If you want the C7000v2 to act as a modem+router, which would allow
        its wireless stuff to work, then the usual way to add a device like your
        (unspecified) "my D-Link router" to it would be to configure your
        (unspecified) "my D-Link router" as a wireless access point, not as a
        full-function router.
           Perhaps that's how it's configured now.  Do devices which are
        connected to your C7000v2 get IP addresses in the same subnet
        ("192.168.0.*", I'd guess) as devices which are connected to your
        (unspecified) "my D-Link router"?
