Sanchez-Pena201's avatar
Sep 17, 2020
C7000v2 can I add VPN
I would like to know if I can add a Norton VPN to my router C7000v2. I found some instructions online but I do not see VPN Service under Advance Setup in my router configuration.
  • FURRYe38's avatar
    Review the user manual for VPN support information. If you don't see VPN there, then this model modem doesn't support VPN features.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    VPN server is not supported on C7000v2.
    Only certain cable gateways such as CAX80 supports openVPN server.
    A lot of our NH routers supports and you can convert C7000v2 to bridge mode modem.
