walshdp89
May 22, 2018Aspirant
C7000v2 Change NAT
My model actualy says c7000v2 I dont know if that matters, but it didn't come up under the model tab.
So I would like to open up the NAT. After doing a NAT-Analyzer I've realized that this router/modem has a "Port Address Restricted Cone NAT"
For gaming its best for this to be "full cone NAT", is there anyway for this to be set or opened?
*i have upnp enabled
Thankyou
- DarrenMSr. NETGEAR Moderator
Have you done port forwarding for whatever game you are playing or console that you are using?
DarrenM
- walshdp89Aspirant
Yes i have, in this particular case I am trying to play Destiny 2. I went to the bungie website and added all of their ports to my routers port forwarding table
