xx2pro4uxx21
Aug 31, 2021Aspirant
C7000v2 connects but no internet
I just got wifi today but I'm running into a problem where my PC connects to the wifi and it says that I have internet access but I'm still not able to connect to the internet. From what I've found on...
- Sep 01, 2021Huh it's working all of a sudden.
Aug 31, 2021Guru - Experienced User
do you mean the internet LED? The C7000v2 doesn't have a wan port.
do you have a screen snip of the cable connections page and the event logs from the modem? Helps check the connection.
xx2pro4uxx21
Sep 01, 2021Aspirant
Alright here's some pictures of everything I could find that might help.
- xx2pro4uxx21Sep 01, 2021Aspirant
- plemansSep 01, 2021Guru - Experienced User
not quite what I was looking for.
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
