xx2pro4uxx21
Aug 31, 2021Aspirant
C7000v2 connects but no internet
I just got wifi today but I'm running into a problem where my PC connects to the wifi and it says that I have internet access but I'm still not able to connect to the internet. From what I've found on...
- Sep 01, 2021Huh it's working all of a sudden.
xx2pro4uxx21
Sep 01, 2021Aspirant
And there's the cable connections page
- plemansSep 01, 2021Guru - Experienced User
You missed out on some channels. Scroll down a bit.
But from the initial, you're not getting all your channels locked.
Try removing any splitters or signal attenuators from your line.
Check for kinks, damage, loose/old/bad/corroded coax cables and remove them if you do
- xx2pro4uxx21Sep 01, 2021AspirantHuh it's working all of a sudden.
- michaelkenwardSep 01, 2021Guru - Experienced User
xx2pro4uxx21 wrote:
Huh it's working all of a sudden.Telepathy.
plemans can perform all manner of magic by remote control.
