Sweedenburg
Nov 06, 2020Aspirant
C7000v2 Daily Slowdown
I've read so many posts about the c7000's that didn't work properly out of the box, or that ultimately had issues with ISP service (account-wise, or physical lines) but none that I can find have my s...
Nov 06, 2020Guru - Experienced User
do you have the rest of the cable connection (rest of the downstream and then the upstream info) info as well as your logs?
the cable connection is just a snip in time. The logs will show us longer term issues.
Sweedenburg
The inability to attach multiple images to a post or reply is incredibly frustrating.
- SweedenburgNov 06, 2020Aspirant
- plemansNov 06, 2020Guru - Experienced User
Thats the router side logs. There should be modem logs showing the connection back to the isp
- SweedenburgNov 06, 2020AspirantThe only other thing I see is under Event Logs.
