WalterS0bchak
Apr 29, 2020Aspirant
C7000v2 disconnecting all wifi bands at random times
I've had this router since june 2019, use comcast and about a month ago we started losing connection every now and then, both the 2.4 ghz and the 5 ghz will go down and the only thing that fixes it i...
Apr 29, 2020Guru - Experienced User
Try turning down the power output of the modems radios as well. This may help with some interferences with nieghboring wifi and congestion. Maybe found under Advanced Tab/Advanced Settings/Wireless Settings
WalterS0bchak
May 08, 2020Aspirant
I went there and couldn't find anything about limiting my power outage, is there anything specific I should look for?
- monrubinMay 09, 2020Aspirant
We are in the same boat. Comcast tech checked my line and denied that there wasnt anything wrong on their end. I didnt buy it. He told me that my modem/router is overheating. i requested their own modem to test and will be arriving Sunday. I will let you know what happens. Had this router since October. Never had a problem with connection when i had their modem. This problem happened since this Covid started. They did maintenance on their server and was fine for a week and its disconnecting again. Following your post also since I need some answers. I hope someone can help us here.
