rbacon277
Apr 25, 2023Aspirant
C7000v2 disconnects every 2 hours
Was there ever a resolution to this issue? I have been experiencing the same issue. My internet service drops every two hours for a few minutes and then it clears up. I'm seeing the same errors:
rbacon277
Apr 26, 2023Aspirant
Thank you Furrye38. It must have been something on the ISP side as you suggested because the issue and errors cleared up yesterday at 13:42:41. I'll let you know if they resume at some point. I don't want to waste your time chasing ghosts. I really appreciate your willingness to help.
Apr 26, 2023Guru - Experienced User
In most cases it is on the ISP side. Glad something got cleared up.
Come back if you need more help or other information.
Enjoy. 📡
