scloer
Mar 20, 2019Follower
C7000v2 Disconnects from Cable Internet Consistently
I am trying to determine why my internet is constantly disconnecting. I always maintain good signal strength to the WiFi, but I lose internet connection anywhere from 10-20 times per day. Can any inf...
DarrenM
Apr 02, 2019Sr. NETGEAR Moderator
Are you seeing many T3 or T4 timeouts in your modems logs?
DarrenM
- ericologistJul 08, 2019AspirantHow do I discern it's a t3/t4 disconnect? I found the log you speak of, and I see multiple disconnects, but I'm not sure what exactly you mean.
I found another issue in the forums dealing with mtu settings, which, according to the solution provided, I optimized, but that hasn't seemed to help. I even switched wireless channels to avoid any outside variables interfering.
