scloer
Mar 20, 2019Follower
C7000v2 Disconnects from Cable Internet Consistently
I am trying to determine why my internet is constantly disconnecting. I always maintain good signal strength to the WiFi, but I lose internet connection anywhere from 10-20 times per day. Can any inf...
DarrenM
Apr 02, 2019Sr. NETGEAR Moderator
Are you seeing many T3 or T4 timeouts in your modems logs?
DarrenM
ericologist
Jul 08, 2019Aspirant
How do I discern it's a t3/t4 disconnect? I found the log you speak of, and I see multiple disconnects, but I'm not sure what exactly you mean.
I found another issue in the forums dealing with mtu settings, which, according to the solution provided, I optimized, but that hasn't seemed to help. I even switched wireless channels to avoid any outside variables interfering.
