BobGear
May 17, 2019Star
c7000v2 Firmware
Looking to download the latest firmware for my Netgear modem.
It is a c7000v2 (AC1900).
I do not find it availbale on the website, via the modem UI, or the Netgear Genie app.
Useful help is app...
- Sep 26, 2019
This hardware had potentional. However the lack up firmware upgrade tools killed it. Sold this junk off on eBay. Goodbye netgear.
May 18, 2019Guru - Experienced User
Combo devices need to be updated by the ISP. End users can't update them.
Here's the list of current firmware version by ISP.
BobGear
May 19, 2019Star
Still looking to download the latest firmware for my Netgear modem....
- plemansMay 19, 2019Guru - Experienced User
what version are you on?
- BobGearMay 19, 2019Star
V1.02.04.
ISP is RCN. I bought it on their recomment, but doubtful they will waste time updating the firmware remotely. Aytime there is an issue they just point fingers at the non-RCN provided gear. So, a firmware upgrade is a good box to check-off on the resolution list.
If an ISP can upgrade it, then so can we. Just need the right tools/software....
- plemansMay 20, 2019Guru - Experienced UserIt's a nice thought but doesn't work. The ISP pushes the firmware when they provision your device. They can contact netgear to get the newest firmware but it has to come fron them.
- alexnewsSep 26, 2019Tutor
v1.02.14
But thinking to change on something better. Because, you can't control your network. With previous router, I can make access by the hours, watch what is going on in my network, this one is really SUX. I don't think will by again Netgear. Any ideas what to buy to really control my network?
- FURRYe38Sep 26, 2019Guru - Experienced User
Bridge your C7000 modem and connect up a external wifi router that has the features that you need.
alexnews wrote:v1.02.14
