BobGear
May 17, 2019Star
c7000v2 Firmware
Looking to download the latest firmware for my Netgear modem.
It is a c7000v2 (AC1900).
I do not find it availbale on the website, via the modem UI, or the Netgear Genie app.
Useful help is app...
- Sep 26, 2019
This hardware had potentional. However the lack up firmware upgrade tools killed it. Sold this junk off on eBay. Goodbye netgear.
May 19, 2019Guru - Experienced User
what version are you on?
alexnews
Sep 26, 2019Tutor
v1.02.14
But thinking to change on something better. Because, you can't control your network. With previous router, I can make access by the hours, watch what is going on in my network, this one is really SUX. I don't think will by again Netgear. Any ideas what to buy to really control my network?
- FURRYe38Sep 26, 2019Guru - Experienced User
Bridge your C7000 modem and connect up a external wifi router that has the features that you need.
alexnews wrote:v1.02.14
- BobGearSep 26, 2019Star
- plemansSep 26, 2019Guru - Experienced User
I think you'll find that any of the combo devices you buy are going to have the firmware controlled by the ISP. Good luck with your next device!
