BobGear
May 17, 2019Star
c7000v2 Firmware
Looking to download the latest firmware for my Netgear modem.
It is a c7000v2 (AC1900).
I do not find it availbale on the website, via the modem UI, or the Netgear Genie app.
Useful help is app...
- Sep 26, 2019
This hardware had potentional. However the lack up firmware upgrade tools killed it. Sold this junk off on eBay. Goodbye netgear.
BobGear
Sep 26, 2019Star
Sep 26, 2019Guru - Experienced User
I think you'll find that any of the combo devices you buy are going to have the firmware controlled by the ISP. Good luck with your next device!
- alexnewsSep 26, 2019Tutor
You are not right, I'm controlling my device, because it is the option to use your own device and get 10$ off per month. But, as a normal person I love all in one device, don't have space to buy new Router and attach to this one.
- FURRYe38Sep 26, 2019Guru - Experienced User
Users have access to the modems web page which is user controllable, thats it. However FW updates are controlled BY ISPs only. NG develops the code, then hands off to ISPs to test and certifiy for use on there network before THEY push out to modems.
Good Luck.
alexnews wrote:You are not right, I'm controlling my device, because it is the option to use your own device and get 10$ off per month. But, as a normal person I love all in one device, don't have space to buy new Router and attach to this one.
