Ron23
Jan 02, 2021Tutor
C7000v2 Guest network
Guest 2.4 GHz shows up in the Advanced Home page. When I click on it to see the settings, it goes to the Guest Network Settings page but it is blank. When I try to enable and add the existing SSID, i...
Jan 04, 2021Guru - Experienced User
What browser are you using? Try IE11, Edge or Firefox or Opera.
Try accessing the modems web page at 192.168.1.1 or 192.168.100.1
Ron23
Jan 05, 2021Tutor
I'm using Chrome. It's a strange situation since I can login w/o any problems and I can see my other wireless networks (non-Guest 2.4 and 5.0) and I can make any changes I want.
It's just the Guest network that's having the problem. When I select my guest network, it goes to a page like shown in this picture. Then I try to add the same SSID name or a new name and I receive the error I listed before.
- FURRYe38Jan 05, 2021Guru - Experienced User
I would make contact with NG support and ask for additional help and information.
