Ron23
Jan 02, 2021Tutor
C7000v2 Guest network
Guest 2.4 GHz shows up in the Advanced Home page. When I click on it to see the settings, it goes to the Guest Network Settings page but it is blank. When I try to enable and add the existing SSID, i...
Ron23
Jan 05, 2021Tutor
I'm using Chrome. It's a strange situation since I can login w/o any problems and I can see my other wireless networks (non-Guest 2.4 and 5.0) and I can make any changes I want.
It's just the Guest network that's having the problem. When I select my guest network, it goes to a page like shown in this picture. Then I try to add the same SSID name or a new name and I receive the error I listed before.
Jan 05, 2021Guru - Experienced User
I would make contact with NG support and ask for additional help and information.
