kaiyoma
Jan 13, 2022Aspirant
C7000v2 has started dropping WiFi regularly, needs to be restarted often
My C7000v2 has started misbehaving as of last night. What happens is that first the 5 GHz WiFi network disappears without warning, then a minute or two later the 2.4 GHz network disappears. At this p...
Jan 13, 2022Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
- kaiyomaJan 13, 2022Aspirant
I don't know when the firmware was last updated (it's pushed by the ISP), but doing a factory reset is probably the next step here. I'll do that tonight. I'm already using channel 40 for the 5 GHz WiFi and that doesn't seem to be helping.
- FURRYe38Jan 13, 2022Guru - Experienced User
Yes, there are many other WiFi networks around (I live in an apartment building). I just checked the gateway's UI and I see eight 2.4 networks and eighteen 5 GHz networks. So, 26 total WiFi networks.
