kaiyoma
Jan 13, 2022Aspirant
C7000v2 has started dropping WiFi regularly, needs to be restarted often
My C7000v2 has started misbehaving as of last night. What happens is that first the 5 GHz WiFi network disappears without warning, then a minute or two later the 2.4 GHz network disappears. At this p...
kaiyoma
I don't know when the firmware was last updated (it's pushed by the ISP), but doing a factory reset is probably the next step here. I'll do that tonight. I'm already using channel 40 for the 5 GHz WiFi and that doesn't seem to be helping.
Jan 13, 2022Guru - Experienced User
- kaiyomaJan 13, 2022Aspirant
Yes, there are many other WiFi networks around (I live in an apartment building). I just checked the gateway's UI and I see eight 2.4 networks and eighteen 5 GHz networks. So, 26 total WiFi networks.
- FURRYe38Jan 13, 2022Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
