laumansm
Nov 06, 2022Aspirant
c7000v2 in bridge mode but wifi is still on
Hi there, I have placed my Netgear c7000v2 cable modem / router into bridge mode ie I turned routing functions off. A downstream tp-link router takes over routing and wifi duties. However, even in br...
Kitsap
Nov 06, 2022Master
laumansm wrote:Hi there, I have placed my Netgear c7000v2 cable modem / router into bridge mode ie I turned routing functions off. A downstream tp-link router takes over routing and wifi duties. However, even in bridge mode, the c7000 keeps turning wifi back on. Only the 5 Ghz channel, not the 2.4. There is no facility in bridge mode to turn the wifi off or on manually. After a reboot, wifi is off but then turns back on. The problem is that this interferes with the wifi that the TP link provides. There is also a manual wifi off/on button in the front of the device. The manual says to push this button for 2 secs to turn wifi off. I tried 1 sec, 2 secs and 10 secs but it makes no difference. The wifi stays on.
I don't think that should be happening in bridge mode, correct? How can I turn wifi off on the c7000 when in bridge mode?
Thank you so much!
The second LED from the bottom is a combination indicator/switch. To turn off the Wi-Fi radios, press and hold for two seconds before releasing. See attached. If you have not done so, go to the Downloads section above and download the manual.
laumansm
Yes, i have tried that, too but it didn't seem to make any difference. Wifi stayed on. Thanks!
- KitsapNov 06, 2022Master
laumansm wrote:The second LED from the bottom is a combination indicator/switch. To turn off the Wi-Fi radios, press and hold for two seconds before releasing. See attached. If you have not done so, go to the Downloads section above and download the manual.
Yes, i have tried that, too but it didn't seem to make any difference. Wifi stayed on. Thanks!I find it very difficult to believe your C7000v2 Wi-Fi is still transmitting when the Wi-Fi radio indicator on the front panel is not illuminated.
Do you have unique SSID's configured for both the 2.4 and 5 GHz Wi-Fi bands on your C7000v2?
Do you have any other devices in the home that transmit Wi-Fi signals with the same SSID's?
What client device are you using to determine the C7000v2 Wi-Fi is still transmitting?
- laumansmNov 06, 2022Aspirant
Yes, the LED is on, and I was unable to turn it off, neither with the physical button nor within the software panel (192.168.100.1). And, yes, the SSID was the same as the one on my router right next to it, which caused a network conflict, which in turn was the reason for me to write here That all said, now that I have turned OneMesh off on the TP-Link router, the wifi on the Netgear cable modem side does not seem to turn back on. I hope that this resolves it for now, except that it will mean that I won't be able to use OneMesh function on the TP-Link router.
- laumansmNov 14, 2022Aspirant
No matter what I did, the device ended up turning on wifi on, over and over again. Rebooting fixed that, only to start again a day later. I ended up resetting the device to factory defaults and then re-enabling bridge mode. For the past 3 days, it has not restarted wifi on its
own. Fingers crossed.
