Bryan_Q
Apr 06, 2023Aspirant
C7000v2 Internet randomly goes out and factory resets on his own
I am looking for some help with my cable modem router. I have a NetGear C7000v2 firmware V1.03.08. I have been having this issue for probably the last 4-6 months. I have tried trouble shooting wit...
Apr 07, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Bryan_Q
Aug 18, 2023Aspirant
Sorry for the months of delay and i appreciate your help. I replaced the coax cable with a new one and also removed the splitter that was added my Xfinity as I only use internet with no cable TV. I thought removing the cable for a new one would fix it, but the issue is still happening.
There's no kinks in the line that I see and the new one is now installed. Removed all cables from the modem and had it completely powered off for +5 minutes.
I can include the event log, but i believe it mentions MAC so I need to blank those out right?
- FURRYe38Aug 18, 2023Guru - Experienced User
Power is WAY TOO HIGH:
Going to burn out the modem eventually.You have a ton of correctables and un-correctables that should be zeros.
Please edit out the MAC ADDRESSES before posting the event log if you see any.
- Bryan_QAug 18, 2023Aspirant
Wow that's a big difference in power. What normally causes the power to be so high? I'm using the original power adaptor and the modem is on top of a dresser with plenty of ventilation.
These are the event logs:- FURRYe38Aug 18, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Especially T3 Timeouts.
The power needs to come down for sure.
https://highspeed.tips/docsis-events/
