Mystery123
Apr 30, 2023Aspirant
C7000v2 internet speed dropped after reconnecting ethernet cable, wifi is still fast.
So I had to move the location of the mode/router and afterwards, direct connection speed is very slow. I was getting 200mbps before and now it caps at around 93mbps. I tried different cables, the s...
May 01, 2023Guru - Experienced User
Did you check to see if its connecting at gigabit speeds?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
A sketchy cable/port can cause slow downs.
Mystery123
May 01, 2023Aspirant
It fixed it by itself.
The light I was mentioning was on the back of the router.
It has two lights on each port on the back.
When it's green, connection is fast. Amber light, connection is slow.
