aguido17
Apr 15, 2020Aspirant
C7000v2 issues
Please help! I have a c7000 v2 WiFi cable router and modem combo and I am always having issues with the tv getting fuzzy picture and freezing a bit. On the router itself, the 3rd light down (Upstream...
Apr 15, 2020Guru - Experienced User
Do you know if the TV supports 5Ghz frequency as well?
Does the TV have a ethernet wired port in back?:
What is the distance between the modem and TV?
aguido17
How can I set channels to 2.4ghz?
