carl4638
Jan 11, 2022Aspirant
C7000v2 Keeps Resetting
I've been experiencing this issue for months now that randomly, there's no fixed time when this happens could be 10pm could be 6am. My C7000v2 router will reset. It won't lose power, but almost all t...
Jan 11, 2022Guru - Experienced User
Log into the device a take a screen snip of the event log and the cable connections page.
Those can tell us if there's line issues causing it or if the reset signal is being sent by the ISP or CMTS.
- carl4638Jan 11, 2022Aspirant
NOTE: REMOVED CMAC AND MAC FOR PRIVACY
UPSTREAM/DOWNSTREAM
Startup Procedure Procedure Status Comment Acquire Downstream Channel 573000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 29 573000000 Hz 5.5 dBmV 40.5 dB 0 0 2 Locked QAM256 41 645000000 Hz 5.2 dBmV 40.3 dB 0 0 3 Locked QAM256 42 651000000 Hz 5.6 dBmV 40.4 dB 0 0 4 Locked QAM256 43 657000000 Hz 5.9 dBmV 40.5 dB 0 0 5 Locked QAM256 44 663000000 Hz 6.3 dBmV 40.7 dB 0 0 6 Locked QAM256 25 549000000 Hz 5.3 dBmV 40.5 dB 0 0 7 Locked QAM256 26 555000000 Hz 5.2 dBmV 40.5 dB 0 0 8 Locked QAM256 27 561000000 Hz 5.2 dBmV 39.8 dB 0 0 9 Locked QAM256 28 567000000 Hz 5.4 dBmV 40.6 dB 0 0 10 Locked QAM256 30 579000000 Hz 5.5 dBmV 40.3 dB 0 0 11 Locked QAM256 31 585000000 Hz 5.4 dBmV 40.2 dB 0 0 12 Locked QAM256 32 591000000 Hz 5.4 dBmV 40.1 dB 0 0 13 Locked QAM256 33 597000000 Hz 5.2 dBmV 40 dB 0 0 14 Locked QAM256 34 603000000 Hz 5.1 dBmV 40 dB 0 0 15 Locked QAM256 35 609000000 Hz 5.1 dBmV 40 dB 0 0 16 Locked QAM256 36 615000000 Hz 5 dBmV 39.9 dB 0 0 17 Locked QAM256 37 621000000 Hz 4 dBmV 39.9 dB 0 0 18 Locked QAM256 38 627000000 Hz 3.8 dBmV 39.9 dB 0 0 19 Locked QAM256 39 633000000 Hz 3.9 dBmV 39.9 dB 0 0 20 Locked QAM256 40 639000000 Hz 4.1 dBmV 40.2 dB 0 0 21 Locked QAM256 21 525000000 Hz 5.2 dBmV 40.3 dB 0 0 22 Locked QAM256 22 531000000 Hz 4.9 dBmV 40.3 dB 0 0 23 Locked QAM256 23 537000000 Hz 4.9 dBmV 40.3 dB 0 0 24 Locked QAM256 24 543000000 Hz 4.8 dBmV 40.4 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 43.4 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 43.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 42 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 41.8 dBmV 5 Locked ATDMA 5 2560 Ksym/sec 40400000 Hz 42 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
EVENT LOG
Time Priority Description 2022-1-11, 13:38:48 Notice (6) WiFi Interface [wl0] set to Channel 4 (Side-Band Channel:N/A) - Reason:INTERFERENCE 2022-1-11, 13:38:47 Notice (6) WiFi Interface [wl1] set to Channel 128 (Side-Band Channel:N/A) - Reason:INTERFERENCE 2022-1-11, 13:38:44 Notice (6) WiFi Interface [wl0] set to Channel 4 (Side-Band Channel:8) - Reason:GUI 2022-1-11, 13:24:30 Notice (6) WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE 1970-1-1, 00:00:49 Notice (6) Honoring MDD; IP provisioning mode = IPv6 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing: 1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;VER=3.0; - plemansJan 11, 2022Guru - Experienced User
You must have just rebooted it. Try it after its ran for a while or after it does a reboot cycle
- carl4638Jan 12, 2022Aspirant
Router was working mostly fine today until a few minutes ago. I pulled this from Event logs just now
1970-1-1, 00:00:49
Notice (6) Honoring MDD; IP provisioning mode = IPv6 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl1] set to Channel 128 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl0] set to Channel 4 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; 1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing; 1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
