cub57000
Jul 16, 2023Aspirant
C7000v2 LAN/WLAN Disconnects every ~15 seconds
Have had this C7000v2 for less than 12 months. Xfinity ISP Firmware Version V1.03.08 - TV started losing wifi intermittently yesterday. The TVs network test would succeed then fail, randomly. A c...
Jul 16, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- cub57000Jul 16, 2023Aspirant
Thank you for the reply.
Connection status: (there is no coax plugged in, intentionally):
Lan connection
Event log
Time Priority Description
1970-1-1, 00:00:40 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:75:23:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:11:47 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:75:23:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:41 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:75:23:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:04:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:75:23:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;What the process looks like, cx-wise
- FURRYe38Jul 17, 2023Guru - Experienced User
Would need to see the requested data with the ISP service coax cable connected.
