Nightsaw
Nov 22, 2023Aspirant
C7000v2 looking to extend network to detatched garage
I am trying to find a way to get a wired internet connection to my detached garage which is about 100 feet away. I can get a coax cable in there but am not sure if there is a way to use that to exten...
- Nov 22, 2023
So if the modem is in the house and you need services at the garage, CAT6A STP lan cabling from the modem to the garage would be recommended, then install a wireless Access Point unit in the garage for wifi services. Any additional LAN ports on the AP could be used for wired devices.
Nightsaw
Nov 24, 2023Aspirant
Thankyou for the advice, is there a wireless access point that would be better than others or something that it needs to have to be compatible with the c7000.
Nov 24, 2023Guru - Experienced User
No. If you're using moca adapter to connect the 2 locations, you can choose whichever access point you'd like.
