Birdage
Apr 20, 2022Initiate
C7000v2 lost range
We've had a Netgear AC1900 WiFi cable modem router, Model C7000v2 for about a year and have Xfinity as our internet provider. Yesterday all of our connected devices had to resign in with the router ...
- Apr 20, 2022
Maybe a power outage caused a reboot/reset?
Have you tried changing the wireless channels for the 2.4ghz/5ghz?
What speeds are you getting? (for wired, 2.4ghz, and 5ghz)
Apr 20, 2022Guru - Experienced User
Birdage
We figured it out. Not sure why the router rebooted by itself since there was no other power outage. Thanks for the help.
- michaelkenwardApr 21, 2022Guru - Experienced User
Birdage wrote:
We figured it out.
For the benefit of others, can you tell us what you figured it out to be?
