Volcar21
Aug 17, 2023Tutor
C7000v2 Modem
Hi Folks, I had a C7000v2 modem/router along with a MR60 and three MS60 mesh system and my cable provider is Xfinity. And recently I started having some reliability issues and contacted Xfinity rega...
- Aug 25, 2023FURRYe38,
Thanks for your response to my issue it is greatly appreciated. I was able to get the MR60 and MS60 connected to the Xfinity modem/router by resetting the MR60 and going through the setup process.
Aug 17, 2023Guru - Experienced User
Would need to see the cable connections and event log page data from the C7000 while it's connected to the ISP services and active to see if there is any ISP signal line issues.
You can turn OFF the wifi radios on the ISP modem and connect the MK series up in AP mode.
Or use the ISP modems DMZ for the MR router in router mode.
Volcar21
Aug 25, 2023Tutor
FURRYe38,
- FURRYe38Aug 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
