Volcar21
Aug 17, 2023Tutor
C7000v2 Modem
Hi Folks, I had a C7000v2 modem/router along with a MR60 and three MS60 mesh system and my cable provider is Xfinity. And recently I started having some reliability issues and contacted Xfinity rega...
- Aug 25, 2023FURRYe38,
Thanks for your response to my issue it is greatly appreciated. I was able to get the MR60 and MS60 connected to the Xfinity modem/router by resetting the MR60 and going through the setup process.
Volcar21
Aug 25, 2023Tutor
FURRYe38,
Aug 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
