USNSeabee
Mar 31, 2023Tutor
C7000v2 Nighthawk AC1900 Cable Modem Router - Extremely slow upload speed
I'm having problems with extremely slow upload speeds. Download speed is great at 470 Mbs, but upload is usually 0.24 to 0.35 Mbs using speedtest.net. My Dell XPS desktop is hardwired to the modem ...
USNSeabee
Apr 04, 2023Tutor
Thanks for your incredibly fast reply! The drivers are up to date. Yes, I think a new ethernet PCI adapter is probably the next step.
Apr 04, 2023Guru - Experienced User
One last test you can try, book the PC into SAFE mode with NETWORKING enabled. Run a speed test there. This would help rule out any apps or security apps causing problems possibly.
