Gringy
Nov 10, 2020Aspirant
C7000v2 no internet connection after power cycling
Hello... I sure hope the community can help me. My c7000v2 usually runs 24/7 no issues, that is if it doesn’t loose power. Spring cleaning, a power outage, or I just want to power cycle the thing cau...
Nov 12, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Please a USB laptop fan cooler under the modem...I have one under mine.
- GringyNov 13, 2020AspirantSo if and when I contact my ISP they have stated that there is a service outage in my area and it’s being worked. This is a running joke for me as every single time I call them they report that to me. Rumor, from my neighbor is our neighborhood node needs updated or the isp has sold service to more customers than the node can actually handle. So basically I get no serious help from them as they don’t wanna do anything like you have suggested they check as the call center just reports that they know of the issue and it’s being worked on 🤪. My internet seems fine though I only have issues like I said when I power off my modem and that’s really it.
