Kyle136
Jul 21, 2019Follower
C7000v2 no lights on at all
Power went out at my house during a storm and the WiFi went down as well. When I checked the router there were no lights on in any color on the box. When I plug/unplug the router the power light flash...
michaelkenward
Jul 22, 2019Guru - Experienced User
Kyle136 wrote:
Power went out at my house during a storm ...
Storms are a great way of killing electronic equipment.
Kyle136 wrote:
Yes, it is hooked to a surge protector and all the other devices plugged into the same surge protector are running normally.
If you have overhead telephone cables, they can get hit by lightning strikes that send a nasty jolt into a modem. I lost a bunch of kit like that once.
If the suggestion from microchip8 doesn't work, then you may be stuffed.
