Jsnmusic101
Jun 05, 2019Aspirant
C7000V2 No WiFi light and can’t router.net
I’ve tried logging in to the router but none of my devices can find the signal to connect to. Only 2 lights on. The power light and the downstream is blinking. Tried pressing the WiFi button and nothi...
Jun 05, 2019Guru - Experienced User
Does a factory reset for 10 seconds then let go and connect a wired PC to the modem and setup or access the setup wizard at 192.168.0.1 work in a browser?
- Jsnmusic101Jun 05, 2019AspirantNot working
- FURRYe38Jun 05, 2019Guru - Experienced User
I would make contact with NG support and get more help. Unit maybe bad now and needs to be RMAd and replaced.
