ctshiroma's avatar
ctshiroma
Follower
Nov 25, 2021
C7000v2 orange light on upload, everything else is green
1 Reply
  • plemans's avatar
    Got a screen snip of the modem's cable connection page? That lets us check your upstream/downstream connections.
    I'd advise removing any splitters, amplifiers, or signal attenuators from your line.
    Check the line for kinks, damage, old/bad/corroded/cheap connections and remove them if you do.
