U298247's avatar
U298247
C7000v2, other network interference
I am a Spectrum customer. I have noticed drastic reduction in speed when other networks appear on my WI-FI Settings page. When they drop off, speed/programming resumes. These intermittent “other” net...
  • FURRYe38's avatar
    Aug 22, 2023
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    There is no router that can be programmed to accept "known network" configurations.
